affiliate and spreadsheet
ezen
Post by ezen »
Wonderful program brought my "antique" Toshiba Satellite back up to "useable status"!<br>75Mhz; 4 megs ram; win95 ! WOW!!!<br>```````````````````````````<br>My questions are...<br>1)Will there be an affilliate program? This software<br>is just too beatiful to keep as low profile!<br>2)Could there be a "LIGHT" spreadsheet program or "add on" in the future? perhaps even integrated in a non software bloating" way<br>  ;D ;D ;D
Re: affiliate and spreadsheet
4 MB RAM? Oh-la! I thought that Windows 95 will not work on such computer.<br><br>About spreadsheets. Who knows...<br><br> ;)
Max_Quordlepleen
Post by Max_Quordlepleen »
One of the best lists of freeware I have found is here:<br>http://home.att.net/~willowbrookemill/p ... sware.html<br>Their spreadsheet section lists a freeware spreadsheet of under 4MB that you may wish to check out. It sounds promising, according to a review <br>herehttp://www.neverexpires.com/software/de ... ?Index=251<br><br>HTH
Salaam alaikum, noho ora mai
ezen
Post by ezen »
Howdie,<br>It's true... only 4 megs ram and 95 runs on the thing! (it "swaps" out alot) But that was about all it would do until...<br>That's why I'm so excited about the software.<br>I'm just "hobbying" around with the Satellite for giggles. But it will be funny if I can get the thing to run all the needed software for less than a hundred bucks<br>And thanks to Max for the freeware leads! I've been all over the place looking for just that kinda stuff for this machine. :D
Prince
Post by Prince »
Have you ever tried Sphyghmic Spreadsheet? Could be the right stuff for you as it's so small that you can put it as a zip-file to a floppy! <br><br>If you like to have e-mail on your little antiquity try FoxMail 1.6 - 295 kb, but it works fine.
Just call me the Prince
Prince
Post by Prince »
Hey, I was to fast. Spyghmic is just the program Max meant. But I do not know it with a size of 3.8 MB.
ezen
Post by ezen »
Those links that Max gave me proved to be a TREASURE! I'll think twice the next time I pass up a 20.00 laptop! SHYGMIC did prove to be perfect for what I had in mind. So the basics are covered. I'm wondering if laptops like these would make perfect student machines (grade school) because not much would be lost. >>>>I know I'm rambleing :-)<<<< I'll check that email program for future use.<br>  8)
