Tables
RedFox
Tables
Post by RedFox »
Atlantis really needs to support tables - its the only reason I don't use it permanently
ambstrako
tables!!!
Post by ambstrako »
I agree with you.. if only it supports tables, it would be so muuuuch better! :(
Melle 8O
Tables are a must
Post by Melle 8O »
I totally concur that tables are the reason for not using Atlantis for more complex documents.
It is impossible to write (technical) documentation without the use of tables.
Please... implement them!!! :arrow:
Tracyjane
Tables please!
Post by Tracyjane »
I've tried Atlantis and loved it! It is a great piece of software except for one glaring omission - it can't do tables. Without table support, the program is not much use to me as I often need to insert them in my documents. As soon as Atlantis can handle tables, I'll register! :-)
zero
Tables are very important - Still waiting!
Post by zero »
Atlantis is a superb product. I am one of the original users and have been delighted to see it get even better with time. But I can't use it for some of my work because ...
It still doesn't have TABLES.
Tables are not a frill. They are essential for technical documents. The message below promised tables 3 years ago, but tables are still not here.
>admin Site Admin
>Posted: Fri Mar 16, 2001 7:30 pm Post subject: Re: Tables?
>Support for tables is scheduled for the next major release of Atlantis.
So PLEASE develop this feature. I'll even send some more money when you do. Thanks!
The “next major version” means Atlantis 2.0.
Atlantis will have all the major features of the top-end word processors (including tables). Please be patient.
andrew
Tables
Post by andrew »
I agree tables are necessary......... and the only reason I do not use ATLANTIS permanently.
The best WP ever !
