atlantis in use by two different PCs & auto correct options
Pakito
Post by Pakito »
Hi there! :D
I am using Atlantis at home and at office.
At Home, I have setup some adjustments of auto Correct, I mean, I established some words to be auto corrected by Atlantis. Now I would like to use the same Auto correct words at office.
I need to know which is the file that I have to copy to a disk to have the same adjustments at office, without having to do this manually. There are a lot of words, so it will be very difficult to me to setup them again at office.
Please, could you tell me how can I solve this?
My name is FRANCISCO and I am Brazilian.
email fpak@ig.com.br
:D
Thanks in advance
Please do the following:
a) launch Atlantis on your home computer.
b) choose "Tools | Options", then click "Save Settings to File" button.
c) transfer a saved "Atlantis.ini" to a home folder of Atlantis on your office computer.
d) launch Atlantis on your office computer with the "-lsi" switch in the command-line (this should be done only once). You could use "Start | Run" to launch this command-line:
"C:\Program Files\Atlantis\Atlantis.exe" -lsi
