Font/Paragraph changes not seen as a redoable operation
dosdan
Post by dosdan »
Select a block. R. click | Font. Change font, font size and attributes. Click on OK. I can't use Ctrl-Y to reuse this change on other block(s) I then mark. Can Font | Paragraph alterations be made redoable?
Admittedly I can use the Copy and Paste within the Font and Paragraph boxes and, in the case of Fonts, use Ctrl-Shift-C | Ctrl-Shift-V, but these require further steps and are not as intuitive as just Ctrl-Y.
MS Word has the "Edit | Repeat" command. If there are no commands for redo, and you press Ctrl+Y, MS Word performs the "Repeat" operation not "Redo".
Atlantis does not have this "Repeat" command. It is scheduled for future releases of Atlantis.
