non-printing characters
Diesel
Post by Diesel »
In regard to version 1.5.0.2, Whatever happened to visible non-printing characters (tab, paragraph, et cetera)? Select all, select none, select any combination, they remain invisible. Not an immeasurably huge deal, but of occasional inconvenience.
Guest
non-printing symbols
Post by Guest »
It's still there. Select what symbols you want to view (under Tools-Options-View-Special Symbols), then toggle their display by clicking the Paragraph marker symbol (next to the zoom percentage).
At least it works for me.
The "Tools | Options" dialog (the "View" tab) allows to specify which special symbols should be visible under the "View | Special Symbols" mode toggled on. If the "View | Special Symbols" mode is off, all special symbols are always invisible.
Diesel
Post by Diesel »
Okay. I hear you both, but no matter which characters I select, nothing shows, and I am unable to ocate a "special symbols" toggle.
Please use the "View | Special Symbols" main menu command (or press Ctrl+Shift+8) to toggle
"Hide all special symbols" / "Show the special symbols specified on the View tab of the Tools|Options dialog".
Diesl
Post by Diesl »
Cool! Thank you. Perhaps my language skills are in decay.
