How Do You Turn Off AutoCorrect????
Eric Gibson
Post by Eric Gibson »
Turning Off AutoCorrect
Can't seem to turn off AutoCorrect. I go to Tools/AutoCorrect Options and unclick the "Autocorrect As You Type" box.
But then when I open up a doc, as soon as I start to type, some words start to appear with a wavy blue underline.
Toggling the Tools/AutoCorrect doesn't seem to help either.
thanks,
Eric Gibson :?:
sml
Post by sml »
Try going to "tools" "options" "spellcheck" and untick the "check spelling as you type" box. Might solve your problem.
Blue wavy underline means that the Spellcheck-as-you-type feature cannot find a spellchecker for the underlined text.
You might need to install the corresponding spellchecker, or disable the Spellcheck-as-you-type feature (as suggested by "sml").
