Latest version 1.5.0.1
Guest
Post by Guest »
I think this was asked in another thread, but can admin tell us what changes, tweaks, fixes, etc. there are in version 1.5.0.1 from the initial release of 1.5.0 as posted on May 16th? Would be helpful. Thanks
These changes are very minor. I do not know if they are worth mentioning.
For example, the "Tools | Options, Load/Save, Backup Files" dialog slightly redesigned. Atlantis also displays a better icon in the System Tray (the Notification area of the Windows's Task Bar). And a fix related to the "widow/orphan control" feature.
I think that all such changes (including very minor changes) will be precisely documented on our site in a not to distant future.
