Printing
Arnoud_Schutte
- Contact:
Printing
I use the Ocean Mind 1.0 registered version. I like the program very much. However, I think I found a bug and that is why I wrote this message.<br>If you create a document of, let us say, 3 pages, and you give the command Print... ,All pages, 3 Copies, then the first 2 pages will be printed 3 times nicely, but the last page will only be printed once.<br><br>Is this a bug or do I make a mistake somewhere?<br><br>Arnoud Schutte.<br><br>
Re: Printing
You are right. There is such problem in Atlantis.<br>The fix will be included to the next build of Atlantis (1.0.0.35).<br><br>Thanks, Arnoud.<br>
