Hi: using latest Atlantis. When I print normally on one side of the paper, font colour is always black regardless of my on-screen colour scheme, as expected. When I want 2-sided printing, the font always prints according to the screen colour scheme in effect for fonts, which might be some shade of blue, grey, or whatever. I'm using a Canon i550 printer. Is there a setting I'm missing? Only occurs with 2-sided printing. Using WinXP Pro. I haven't run into this before so would be glad for any insight here...
John
2-sided printing
John Stafford
2-sided printing
OK. That's great! Soon I hope - I do a lot of double-sided printing. I'm suprised I didn't pick that up during the beta. Also, is there a list of the tweaks that appear in 1.5.01 - just interested.
John Stafford
2-sided printing
Hi: I don't think the text colour problem in 2-sided printing has been fixed in 1.5.0.2. I still get the problem of text picking up the on-screen colour scheme colour for auto text. In some colour schemes it doesn't matter as the text is black anyway, but if you use the Sleepwalker's Fantasy colour scheme for example, nothing prints at all because the auto text colour is white. Could you look at this one again? Thanks. John
John Stafford
2-sided printing
You are correct. I had 1.5.0.1. I thought I had updated but clearly had not. All's well now. Sorry to trouble you, and thank you for the help. John
