Default Font
jsbach1v
Default Font
Post by jsbach1v »
Anyone know how to change the default font from Courier?
I have tried to do this by changing the font in the Styles (Normal) box but it only applies to that particular document and not globally.
Any suggestions?
Thanks.
Please see this thread:
http://www.rssol.com/forum/viewtopic.php?t=131
The incoming version will allow to do this in a much simpler way:
jsbach1v
Default Font & another question
Post by jsbach1v »
Many thanks - much appreciated.
Another question... Is it possible to change the default saving of files from RTF to Plain Text without having to choosing Text in the Save As Menu each time?
This is one great word processor!!
Please choose "File | New | Formats & Templates..." menu command, then use the "Default format for new documents" box to select the desired format.
Guest
Post by Guest »
Great - thanks a lot
