ANCHORING LOCALLY?
ANCHORING LOCALLY?
Can you tell me is there the ability to anchor to another local page within a document? How would I do this? Like a local link.. know what I mean?
You can create a hyperlink to another document or file, or to a location within the same document.
As a first step, you should mark the desired location with a bookmark (click the location, then use the "Insert | Bookmark..." command to insert a bookmark).
Now you can insert a hyperlink. The "Insert | Hyperlink..." dialog contains the "Bookmark" button. Use it to create a link to a bookmark.
