A nimbler capitalization
Gilbamesh
Post by Gilbamesh »
Atlantis is great and I found the transition from MS Word exceptionally easy.
Still I keep missing one feature: cycling a word (or a set of contiguous words) between 'all-capitals', 'all-lower-case' , 'capitalized-initial' through a single key combination.
Doing that through the Edit menu or through different CTRL/SHIFT/F3 combinations feels sort of cumbersome and rules out the possibility of capitalizing on the spot just the initial(s).
I agree that it's a minor issue, but on the long run such a feature would allow to type more fluently thus saving a lot of valuable time.
Re: A nimbler capitalization
It will probably be added as “Cycle through case” (Shift+Alt+F3). Maybe next month. Thanks.
Gilbamesh
Post by Gilbamesh »
Thank you for listening and replying this promptly! Doesn't happen every century... :wink:
This command is available in 4.4.2.1.
Gilbamesh
Post by Gilbamesh »
admin wrote: Fri Nov 08, 2024 10:37 am This command is available in 4.4.2.1.
THANKS!!! :D
