line spacing
sml
line spacing
Post by sml »
I am using the latest version of Ocean Mind (1.1.2.8). I am having trouble with the line spacing function in the "paragraph format" menu. When I create my document with "1.5 lines" line spacing and then save it as a "MS Word 97/2000" document, Altantis does not seem to code the file properly, so that when I open it again with Word 97, the line spacing is indicated as "at least 18 pt." I then opened this file with another program that reads MS Word files (Software 602) and the same thing happened, so the problem seems to be with Atlantis. Any help you can provide will be appreciated. I could send you the file if it would help you to diagnose this problem. Thank you.
A fix will be included to the next build of Atlantis Ocean Mind. Thanks.
