AWP doesn't embed unusual fonts#2 and crash
LightDrop
Post by LightDrop »
Hi there
I worked on some books yesterday and again it doesn't embed a font, this time 'Sava Pro Regular'... (see pic -> Sava01)
On another book I worked on - or better, some books in an a Document-Project - I've got some errors (see pics)
and the Document crashed with an emergency saving -
in on case the whole AWP was frozen and I had it to close via Taskmanager - in two others I was able to work further and load the emergency saving.
All cases occured after an Undo-Operation...
regards
Re: AWP doesn't embed unusual fonts#2 and crash
On my system, "Sava Pro Regular" gets embedded correctly. I assume this font is available in your system, you have not added it to the "font embedding exceptions", and you are not using a pre-4.2.0.3 build of Atlantis. Right?
Is the Undo error reproducible on your system?
LightDrop
Post by LightDrop »
Yep, you are right in all points.
If it's reproducible currently I don't know, but I'm working on that and give feedback if so
regards
