Hi there
AWP doesn't embed some unusual fonts like Yale Small Caps or Uncial Antiqua; the font appeares in the css-file, but isn't embedded.
See screenshot -> and css-file ->
I can do this manually, but I work with AWP to avoid this...
Please help
AWP doesn't embed unusual fonts
Re: AWP doesn't embed unusual fonts
Could you please email these font files to support@AtlantisWordProcessor.com ?
Yeah,of course. But please keep in mind that this are just examples...
Thanks. We have emailed you a test build.
Hi
for what ever reason I have currently no access to my mailaccount.
Could you please send it to -> CPerzl@aol.com
Much thanks
Much thanks
OK, sent.
Hi
Got it, Thanks!
I insert your mail here
First of all: it embeds the 'Uncial Antiqua' and 'Yale SmallCaps' now, as well as some other fonts, it haven't embedded before - but in case of 'Uncial Antiqua' it has partially strange results: the whole body-text of the book displays bold, but I can't find a reason for...
I add two screenshots for clearence...
In one you see body-text and heading in 'Uncial Antiqua', the other one shows css-file - both in Sigil
In the css you can see that it embeds 'Uncial Antiqua' and 'Cambria' but not 'AGaramond RegularSC' - for what reason ever
Beside that another difference is, that in the dialog for 'import styles' I'm no longer able to check the first item I want and pressing shift-key for the last item...
Instead I had to check all one by one
That's it for now - HTH
regards
Got it, Thanks!
Now I've spent half night for checking some files with different files and fonts - and yeah - there is a difference.Run Atlantis, and try saving your document as eBook with font embedding.
Any difference?
Best regards,
The Atlantis Word Processor Team
regards
- css
- Atlantis-1-2.jpg (201.4 KiB) Viewed 7471 times
- body-text
- Atlantis-1.jpg (327.54 KiB) Viewed 7471 times
You can still use Shift+click in the "Import styles" dialog. But since the current version of this dialog uses a check list box, you are supposed to click check boxes not the style names.
You can also click the "Styles to import" box of the "Import styles" dialog, and press Ctrl+A to select all styles.
The next release of Atlantis will have the "select all" box in the "Import styles" dialog:
