Let sentences continue on the same line for as long as possi
RobC
Post by RobC »
I wonder if the following is possible.
If a large document (for example after using OCR on a book) has sentences in many places that continue halfway on the next line, is it possible to automatically have these sentences continue on the same line for as long as possible?
This would be a great benefit when crafting an ebook. :?:
This sentence is too early - example.docx
Hope this example makes it clear !
(12.21 KiB) Downloaded 1013 times
Atlantis has a command/button to “Join paragraphs”. The corresponding hot key is Ctrl+Shift+U. It is part of the Edit toolbar buttons:
If it’s not already on your toolbars, you can add it through “Tools | Customize > Toolbars…”
You only have to select the lines to join and click on that button.
RobC
Thanks for this solution
Post by RobC »
Thanks for this solution Robert, yes this does the job !
I am glad, this saves me a lot of work !! :D :D
