Window size is small when I open or create a document
JPh1
Post by JPh1 »
It's a not a real problem but it keeps bugging me.
Whenever I open a document, or create a new one, the window is very small. I can resize it of course, but I don't recall AWP doing that before (I'm using 4.0.6.11).
Is there a setting I changed unknowingly?
There are plenty of windows in Atlantis. What window do you mean?
JPh1
Post by JPh1 »
I mean the document window, as in the attached picture, where I created a new document.
If you do not want to see the cascade of the document windows, you can switch back to the maximized state of the document windows. Just double-click the title bar of the document window.
JPh1
Post by JPh1 »
Of course. Because I keep a number of open documents with resized windows I had forgotten the cascading hierarchy. Thanks.
JPh1
Post by JPh1 »
Things are back as they were for some reason.
With the same configuration as above and the same open documents, a newly created document has now a sizeable window. It's rather confusing - but as I said not very important.
You can double-click the title bar of the document window to make it non-sizeable.
You can choose the "View | Cascade" menu command to make the document windows sizeable.
