Big Green Question Marks???
Mandolina
Post by Mandolina »
Hello again. I seem to have suddenly got question marks in front of all my Atlantis file names now instead of the nice blue Atlantis logo. Will I lose all my files if I shut down? What have I done?
There is nothing in the help menu under big green question marks!
Probably another application has associated itself with the RTF file extension. In other words, when you double-click an RTF document, another application is used to open this RTF document.
If this is your case, you could easily change this. Use the "Tools | Associate With Document Type..." menu command of Atlantis Ocean Mind to re-associate it with the desired document type (as I understand, with "rtf").
You would lose nothing. Those are just icons. The document files themselves should be unchanged.
Even if another application is associated with the RTF file extension, you could still open the RTF documents with Atlantis. Simply launch Atlantis, and use its “File | Open…” command.
Mandolina
Post by Mandolina »
Yes, thank you. No idea what other program associated itself with .rtf files, but I will figure it out. :lol:
