Is it possible to make text vertical in Atlantis?
In a narrow table cell for example?
Vertical text
Hi Panopticus,
It is actually possible to make text vertical in Atlantis. You can place it either as
a) text in a table column
b) a picture in a table column
c) a picture watermark in a document header
Here is how to proceed:
You need to create the vertical text first:
1. Type the text that you want to make vertical.
2. Use the Ctrl+H dialog with
Find = ^?
Replace = ^&^l
3. Select and copy the results.
You can now simply paste the clipboard contents into a table column. See attached “Vertical Text in Atlantis Word Processor (1).docx”.
You can also create a new picture in a graphical software like MS Paint, and paste the clipboard contents into a text box. Adjust size and colors as desired. Save the picture, and paste it into a table column in Atlantis. See attached “Vertical Text in Atlantis Word Processor (2).docx”.
The same picture with vertical text can also be pasted as a floating picture into the header area of a document in Atlantis. You can then stretch the picture to cover most of the document page. It will act as a kind of watermark. See attached “Vertical Text in Atlantis Word Processor (3).docx”.
Please have a look at these 3 sample documents. Let us know if you need more detailed explanations.
HTH
Find = ^?
Replace = ^&^l
HTH
- Vertical Text in Atlantis Word Processor (3).docx
- (56.66 KiB) Downloaded 521 times
- Vertical Text in Atlantis Word Processor (2).docx
- (51.54 KiB) Downloaded 499 times
- Vertical Text in Atlantis Word Processor (1).docx
- (27.02 KiB) Downloaded 532 times
Panopticus
You need to create that kind of “vertical text” as a text box in a graphical software like MS Paint, and save the picture to your disk.
You can then paste it into a table column in Atlantis. See attached “Vertical Text in Atlantis Word Processor (2b).docx”.
The same picture with vertical text can also be pasted as a floating picture into the header area of a document in Atlantis. You can then stretch the picture to cover most of the document page. It will act as a kind of watermark. See attached “Vertical Text in Atlantis Word Processor (3b).docx”.
Please have a look at these 2 new sample documents. Let us know if you need more detailed explanations.
HTH
HTH
- Vertical Text in Atlantis Word Processor (3b).docx
- (81.08 KiB) Downloaded 461 times
- Vertical Text in Atlantis Word Processor (2b).docx
- (75.95 KiB) Downloaded 443 times
