MS Word does a rather good with when you try to replace "straight quotes' with “smart quotes”. Suppose my text says:
'I don't like this',' I said.
If I activate the "use smart quotes" feature in MS Word, I only have to do a search and replace of ' by ' (yes, I actually type the same character in both fields!), and MS Word will "magically" turn it into this:
‘I don’t like this,’ I said.
(And ditto for " versus “ and ”.)
Atlantis is definitely as good as MS Word at turning ' into ‘ and ’ on the fly, as I type, which is mostly what I need. It doesn't entirely understand the Dutch rules for ‘ versus ’ when it's used elliptically. (This use differs slightly from English.) But that's no great matter, since that doesn't occur very often.
But when I have a piece of text where all the quotes are in "straight" quotes, I see no easy way of converting these to smart quotes. Sure, I can do search and replace actions with <space+'>being changed into ‘ and <'+space> into ’, but that doesn't cover everything. So for that I usually revert to MS Word and quickly do a "smart" search and replace there.
Is that indeed the easiest way, or am I overlooking something basic in Atlantis that will enable me to do it there as well?
MTIA.
replace apostrophes with smart quotes
To change “smart (curvy)” quotes into "straight" quotes:
Select the target text.
Press Ctrl+H.
Enter a straight quote into the Find What box.
Enter a straight quote into the Replace With box.
Press Replace All.
To change "straight" quotes into “smart (curvy)” quotes:
Click “Tools | AutoCorrect Options…”
In the AutoCorrect Options dialog, make sure that “Replace quotes with…” is activated.
OK out of the AutoCorrect Options dialog.
Click “Tools | AutoCorrect…”
When Atlantis suggests to replace “straight” with “curly” quote, press the “Accept All” button.
Press Ctrl+H.
Press Replace All.
Apostrophes
Looking for help on smart quotes in Atlantis - I came across my own message from 2004!
Now the problem still seems to exist. (And even my old friend Frank Lekens faces it.) How to do a search and replace to get smark quotes instead of vertical ones? In this case I mean single quotes. ‘xxx’I note that Atlantis intelligently supports left and right quotes and apostrophes... (single and double quotes) - unless you want to replace an unintelligent single quote (a vertical bar) with an intelligent apostrophe (a small 9). Then it doesn't seem quote so smart... Maye this is a feature request??
Rgds
Martin
The same method applies.
To change “smart (curvy)” single quotes into "straight" single quotes:
Press Ctrl+H.
Enter a straight single quote into the Find What box.
Enter a straight single quote into the Replace With box.
Press Replace All.
To change "straight" single quotes into “smart (curvy)” single quotes:
Note.
If you do not want Atlantis to replace straight with curvy quotes automatically, simply turn off “Replace "quotes" with ...” in the “Tools | AutoCorrect Options…” dialog:
Press Ctrl+H.
Press Replace All.
Note.
