Uninstall Problem
Matt640
Uninstall Problem
Post by Matt640 »
I recently installed the program Atlantis Nova 1.0 Version 1.0.0.60 on my comp (running Win2Ksp3), and although it was very nice and richly featured, I really have little use for it and tried to uninstall...which I could not do...
I keep getting the error message "Could not open INSTALL.LOG file", and don't know whether this is a problem with the program or my system...
Any thoughts on how to get this program uninstalled? Thanks. :)
The home folder of Atlantis should contain the Install.log file. If this file is missing, probably you have manually deleted it.
To uninstall Atlantis Nova manually, delete the home folder of Atlantis Nova, and its shortcuts from the Programs menu and the Desktop (if any).
Sly
Tip
Post by Sly »
Same problem for me.
In install.log, you can see this line :
C:\PROGRA~1\Atlantis Nova\UNWISE.EXE C:\PROGRA~1\Atlantis Nova\INSTALL.LOG
So use the DOS command-line to launch from the directory of Atlantis :
unwise.exe install.log
Hope this helps.
