Thanks — Horizontal line !
rstroud
Post by rstroud »
It is really nice to be able to insert a horizontal line and edit it.
Thank you!
rstroud
More on horizontal line
Post by rstroud »
I did not really test the horizontal line until today.
I discovered a problem.
The line thickness always reverts back to 1.5 points after a file is closed and reopened. You can create a horizontal line with a thickness of, say, 1.0 point, but after you save and reopen the file the line is once again 1.5 points.
This happens even if you set the default to something besides 1.5 points.
If you are not able to replicate this problem, I will send you a file that exhibits the problem.
Incidentally, the named font, in the panel at the right, for the horizontal line paragraph is always Times New Roman, even if the paragraph style uses another font. It is possible to change the font, but the named font for the horizontal line always reverts to Times New Roman when the file is reopened.
Windows 10 and 7
Atlantis 3.2.10.1
Fixed in version 3.2.10.2. Please update your copy. Thank you.
rstroud
Thanks - Horizontal line fixed
Post by rstroud »
Thank you for fixing the problem quickly. I have downloaded the update. :)
