Feature suggestion: "save all" and "change ca
franklekens
Post by franklekens »
Two minor feature suggestions:
I frequently use "save all". It would be nice if it had a shortcut key as well.
My suggestion would be CTRL+SHIFT+S. (I'm assuming that isn't taken yet.)
Secondly, I slightly prefer the way SHIFT+F3 works in MS Word, how it toggles you through the various case options.
Alternately, a shortcut key for Sentence and Heading case would do.
You can assign a hot key to any command through the "Tools | Customize | Hot Keys..." main menu command.
franklekens
Okay, that's good enough. I overlooked that option, somehow thought Atlantis didn't provide it for some reason.
You can assign a separate hot key to each of the 5 "change case" commands.
