Highlight all instances of selected text
MaximilianKohler
Post by MaximilianKohler »
Notepad++ has an awesome feature that when you select a word or phrase it will automatically highlight all other instances of it. Web browsers have a similar feature with the "ctrl+f" -> highlight all. I prefer the notepad++ style, but even the other one would be appreciated. Thanks!
At this point, you can use the "Find & Select All" button in the "Find / Replace" dialog, then the "Show more selections" button of the "Edit" toolbar to navigate among selected items:
franklekens
Post by franklekens »
This is really great, you know. I never even asked for this feature myself, never thought of it, only noticed it on the latest update -- and I already find it's useful to me. Thanks.
MaximilianKohler
Hi, thanks a lot for adding this!
I just have one bit of feedback: The other text that gets highlighted is done so significantly dimmer to the point where it's hard to tell that it's highlighted at all.
I checked in "options -> colors" tab for a way to make it more obvious, but the only option I see is for changing the general highlight color, which doesn't remedy the problem.
I also tried unchecking "optimize onscreen contrast of text colors". And I also tried selecting text than clicking the "highlight" shortcut (which I intended to undo after scrolling through to look over the text), but that only highlighted the one instance, rather than all of them.
For me, I think the ideal fix would be to both make it darker and possibly adding an option to make it a different color. Looking at the way notepad++ does it, they don't change the color, but it's darker (though not as dark as the original highlighted text).
When you select a fragment of text and there are other occurrences of the same fragment in the document, they get numbered in the status bar:
If you click on that number, all the occurrences are automatically selected, and appear as a proper multiple selection:
