I would like to be able to set this Font as default
357mag
Post by 357mag »
I wish that you could set a default Font and Size and Atlantis would remember it so when you closed and opened the program up again your favorite font would automatically be there.
I almost always use Times New Roman 12pt.
A suggestion.
The default font type and size is the one found in your Atlantis template for new documents (Ctrl+N). By default, it is “Normal.rtf”, and it is located in “C:\Users\<USER’S NAME>\Documents\Atlantis\Templates\”. All you need to do is open this “Normal.rtf” file in Atlantis, press Ctrl+A, and set the font type and size as desired. Save your changes by pressing Ctrl+S.
357mag
Post by 357mag »
Excellent. Thank You Very Much.
Just what I wanted and didn't know you could do.
You can also use the "Default" button of the "Format | Font..." dialog to change the default font. The "Default" button is also available in the "Format | Paragraph..." and "File | Page Settings..." dialogs.
