remove manually a number format of the paragraph in a list
Leopoldus
Post by Leopoldus »
I have a numbered list and need to remove manually the number from one specific paragraph in the list, but to avoid breaking all other paragraphs numbers formatting. But when I try to use the BackSpace key or press a toolbar button [Numberring] in order to remove the leading number from this paragraph, I get the following error message:
"The list format of the selected paragraphs is style-controlled. Direct formatting cannot be used to override style-controlled list formatting." and so on - please look at the attached screenshot.
Is there however any way to remove the number from the specific paragraph / list item? Thanks!
Just associate the paragraph with a different style.
