Unable to use Atlantis Ocean Mind
Guest
Post by Guest »
Trying AOM for few days. Every time I start typing, - it is very slow, and after some characters it gives error in kernel.exe and stops working. Couple of times it locked win and must reboot.
I have P166/64MB RAM.
Any suggestions?
-HF
Your sound card driver might be unable to play sounds asynchronously.
Try to disable the sounds in Atlantis. Choose "Tools | Sounds...".
Click "Disable All". Or click the "Press Key" item from the "Events" box, then uncheck the "Enabled" box.
