Little bug with Preview
Eduardo
Post by Eduardo »
i there!
I write mainly in full screen mode (F9) + Draft mode (Wrap to window) selected.
I often use Preview (Ctrl+ F2) to check the page. However, when I press Ctrl+F2 again to take me back to the previous window (full screen mode (F9) with Draft mode (Wrap to window) the right part of text is not visible. I have to scroll the wheel in order to make it visible. Please take a look at this minor bug.
Thank you for your ongoing efforts. This is a great program.
Eduardo
Eduardo
Hi Eduardo!
Which of the following boxes are checked or unchecked in your “View” global options:
Also which zoom factor are you using?
Eduardo
Post by Eduardo »
Hi Robert!
Thanks very much for your prompt reply.
The boxes I have unchecked are as follows:
- Tab characters
- Spaces
- Windows taskbar
- Pictures placeholders
The zoom factor in 130%
Thanks again.
Eduardo
Could you please open Atlantis, click “Tools | Options…”, press the “Save to File…” button, and send the saved “Atlantis.ini” file to support@AtlantisWordProcessor.com? TIA.
Eduardo
Post by Eduardo »
Hi Robert!
I have sent you the ini file.
Thanks again.
Eduardo
Thanks for the INI file. Is this glitch happening with all documents or only with some? If it is happening only with some document(s), could you please send it to support@AtlantisWordProcessor.com?
Eduardo
Post by Eduardo »
Hi Robert,
This glitch happens with all documents, regardless of page margins. I did a bit of testing today and the results were the same.
Thanks again for looking into this issue.
Regards.
Eduardo
We will look into this problem. Thanks.
Eduardo
Post by Eduardo »
Thanks very much.
Regards.
Eduardo
A fix will be included in the next release. Thanks.
Eduardo
Post by Eduardo »
Thank you very much for the effort. Much appreciated.
Eduardo
