Atlantis 2.0 and 4K UHD screens - icon size
wcpeace
Post by wcpeace »
Still using Atlantis 1.6.6.1 here. Does Atlantis 2.0 have better support for 4K / Ultra HD / High-DPI screen resolutions? I'm using the LARGE BUTTONS and I disabled display scaling as it looked blurry - the menus.
The buttons are still a bit small. Thanks.
Sorry, but the present version of Atlantis does not support such screen resolutions.
wcpeace
Post by wcpeace »
Thanks. In some very simple testing, it appears to be usable...though there might be an issue with directly printing from the program...as long as I can print to PDF, that's ok.
I'll know more soon. The small(er) icons, I can live with. They are crisp and clear without display scaling.
Are you aware of any particular issues?
Any timetable on when you plan to update the program?
Are there any other problems besides the toolbar button size?
wcpeace
Post by wcpeace »
Just starting to use it...this is the first thing I've noticed. See attached PDF of screen shot.
Dialog box has small icons....by THIS PC, and the tab on the right is a little off.
I'll report more as I find them.
atlantis_screen_capture.pdf
(97.02 KiB) Downloaded 619 times
