printing cvs label list to envelopes
TexasPete
Post by TexasPete »
Do I have to convert cvs file to label list to a text file . I want to print the list to some envelopes. I did not see instructions in help file list.
Texas Pete
To convert CSV to TXT files, you could go to Convert CSV to TXT Online Free
TexasPete
txt conversion from csv
Post by TexasPete »
Robert thanks for the link. I tried it and the text file came back split up. Names and address were not on the same line. I may have to literally write code to change it.
Thanks
Texas Pete
I am sending you the file in case you have a simple idea.
If you mean to create an address book for Atlantis, it needs to be formatted as explained at Address Books
Did you send your file to Support@AtlantisWordProcessor.com?
