Fonts won't change
Franklinr
Fonts won't change
Post by Franklinr »
Sometimes I have to edit files created in OpenOffice Writer or one of its derivatives and when I open it in Atlantis, the fonts look different. I always save the file in Atlantis own RTF format but it still retains the ugly font. I'm very familiar with how to select my fonts based on styles and often change the fonts and styles as needed. But with this file it says that it is Normal but it's not. Need some help here. :(
It is difficult to tell what is really happening without a sample document. But most of the time a particular font won’t display correctly because it is not installed on the current system. The results might look “ugly” when Atlantis has to find substitutes for fonts. Always make sure that the fonts used in your documents are installed on the current system.
