Out of memory
Victor
Out of memory
Post by Victor »
:cry:
A problem with Atlantis Ocean Mind. Open a text file (999 pages), select all, change font to any, a exception:
"Out of memory. Raised while executing sensitive operation. Document C:\my documents\1.txt will be closed".
A bad memory gestion in Atlantis ?. The memory of my computer is 511.0MB.
You have found a memory leak in Atlantis. A fix will be included in the next build of Atlantis. It should be available shortly. Use the "Help | Check For Updates…" menu command to update. Thanks.
Guest
Post by Guest »
Thanks for your speed support :D
