Pagination Differences Between Windows 7 and Windows 8
mgclark
Post by mgclark »
I run Atlantis on my Windows 7 notebook and on my Windows 8 desktop and have a problem with pagination. I am writing a 200-page textbook with lots of images and Atlantis will put the page breaks in different locations in the same file, depending on whether I open the file in a Windows 7 or Windows 8 machine. Any thoughts on why this would be...and how to fix it?
Thanks!
This is because word processors paginate documents differently depending on which printer is default when the document is displayed or printed.
Here is from Word's numbering explained:
It is worth mentioning that in Word, "pages" do not exist in the document file. Like a professional typesetter, Word makes up its pages on the fly when it displays or prints a document. Word uses measurements from the installed fonts and the installed printer driver to do this. It is almost impossible to get two machines so exactly similar that a document will paginate with exactly the same page breaks on each. Sometimes people complain that when they open the document on a different machine, some of the page numbers in the TOC or Index are "wrong". They're not: when the document is opened on the other machine, minute variations in set-up that do not show over a ten page memo will cause variations in the position of page breaks in a 1,000-page manual. If you remember to update the TOC and Index before you print, the problem corrects itself.
mgclark
Post by mgclark »
This is helpful information. Thank you.
DaleDe
Post by DaleDe »
If you want the page numbers to remain the same you can do it. Take the version with the least number of lines and insert a manual page break on each page. (On the insert menu).
This can be particularly annoying if you send someone a word document to be read like a book. It is not only the printer and fonts that affect this. I have found that word and Atlantis differ on the same machine.
Dale
