Problem with hungarian characters with double acute accents
imaginer
Post by imaginer »
In the text, if there is some kind of style of the text then breaks those characters.:
<p class="p2"><span class="t3">Erzsébet hercegn</span><span class="t3">&#337;</span><span class="t3"> és Fülöp árulkodó pillantást vet <br/>egymásra rokonuk, Lady Patricia Mountbatten esküv</span><span class="t3">&#337;</span><span class="t3">jén, <br/>1946 októberében. </span><span class="t4">TopPhoto/The Image Works</span></p>
In normal (regular font) style is no problem
http://en.wikipedia.org/wiki/Double_acute_accent
Did you mean to say that the Hungarian umlaut character is not properly rendered in Atlantis on your system?
What exactly do you mean by “some kind of style”? Are you talking about styles like the “Heading 1”, “Heading 2” styles as opposed to the “Normal” style?
What exactly do you mean by “normal (regular font) style”? What do you mean by “normal regular font”? Did you mean to say that the Hungarian umlaut character is not properly rendered in Atlantis when you use some specific font faces? Which font faces?
Which version of Atlantis are you running (Help | About…”)? On which Windows system?
Could you please have a look at the attached document. Does it display correctly in Atlantis on your system?
Could you also please post a sample document in which the Hungarian umlaut character is not properly rendered in Atlantis on your system?
Thanks.
Hungarian_test.docx
(3.28 KiB) Downloaded 684 times
imaginer
Post by imaginer »
win 7
1.6.6.1 (all character displayed correctly in atlantis)
not the hunumlaut (ö, ü) is the problem.
Just this 4 character: http://en.wikipedia.org/wiki/Double_acute_accent
(my english is very poor :D )[/img]
Screen Shot 2014-03-05 at 13.32.04.png (235.5 KiB) Viewed 13507 times
Screen Shot 2014-03-05 at 13.31.49.png (48.2 KiB) Viewed 13507 times
Screen Shot 2014-03-05 at 13.33.15.png (25.74 KiB) Viewed 13507 times
Screen Shot 2014-03-05 at 13.33.50.png (28.98 KiB) Viewed 13507 times
Screen Shot 2014-03-05 at 13.54.52.png (12.71 KiB) Viewed 13507 times
By the way, which is the default keyboard layout on your Windows system?
Please have a look at this second test document. Does it display correctly on your system? If not, could you please post a screenshot of its display in Atlantis on your system?
Here is how it displays on my system:
Also why exactly did you post a screenshot of HTML code? Atlantis is not supposed to deal with HTML code.
Hungarian_test_2.docx
(4.25 KiB) Downloaded 627 times
imaginer
Post by imaginer »
:oops: I forgot to write: the EPUB export is the problem
sorry
:oops:
imaginer, could you email your source document file (RTF, DOC, or DOCX) to support@AtlantisWordProcessor.com?
Most current eReaders cannot display the accented characters of languages other than English because their built-in fonts do not contain the corresponding glyphs. To make sure that these accented characters will be displayed correctly on all eReaders, you need to save your source documents as EPUB with font embedding. For detailed explanations, please have a look at this entry from the Atlantis blog:
Font embedding in eBooks
I have saved my previous test document in Atlantis as attached “Hungarian_test_2.epub”. I have saved it with font embedding. Its Hungarian double acute characters display correctly in all eReaders. Please, have a look.
(1.89 MiB) Downloaded 709 times
imaginer, thanks for the document file.
The HTML code generated for those characters is not optimal. I believe this is a minor issue. But it will be corrected in any next release of Atlantis.
If you want this fix in your version of Atlantis, please run this setup file.
imaginer
Post by imaginer »
i hope too
imaginer
Post by imaginer »
It works! Thank you very much :D
imaginer
Post by imaginer »
It was very quick fixing
:D
