I have a less-than-one week old installation of Windows 7 64-bit and a registered copy of Atlantis WP. My problem is that I am getting very small and hard-to-read text in Atlantis pop-up menus. I have posted a screenshot at http://gyazo.com/5b27cfe442b31025c3d0cc3c3258d5db showing one example of the text in the spelling pop-up.
Is there any way to make the text larger? Thank you.
Frank D
Unusually small type font in dialogs and lists - How to fix?
frank14612
frank14612
Dale,
No, it has no relationship to the size of the fonts on the Desktop or in Windows Explorer, which are all set to the default font, Segoeui.ttf, 9 point. As you can see from the screenshot, the font is definitely not Segoe, since the Windows Segoe font is sans-serif, while the font in the Atlantis pop-up is serif. So there's more afoot than just setting the size of the Windows font.
The answer may lie in where Atlantis gets its dialog box/pop-up menu font/font size from.
Frank
Frank
frank14612
Yes, I checked, and found all those fonts installed.
Just to illustrate that my Windows Desktop font is normal, I took this screenshot: http://gyazo.com/37fba0f0ad7c256dd928583489ed121f.
I haven't seen this particular issue addressed anywhere on the Web. If it is brought up in the usual form, "How do I adjust my Windows font and size?" it is answered with the routine, "Click on the Desktop > Personalize > Window color > Item, and then choose your preferred font and size." My settings, where a font and size are applicable, are all set to Segoe UI, 9 point.
Frank
Frank
frank14612
frank14612
frank14612
Solved!
Genius!
Reinstalling the Arial font solved the problem.
I couldn't have figured it out myself without knowing that there was a missing font and what the missing font was.
Thank you!!!
Frank D
P.S. Curious why neither MS Word nor Wordpad had the problem.
Thank you!!!
Frank D
- Capture.PNG (66.39 KiB) Viewed 10912 times
