using wildcard search results as part of replace
DaleDe
Post by DaleDe »
Is it possible to use the results of a wildcard search results in the replace portion? Is it collected in some fashion to be reused? If not then I would like to suggest this change.
Dale
It is done with the “^&” special symbol. Please, have a look at New special characters, and in particular, the special characters that can only be used in the “Replace with” box.
Here is an example (taken from the attached document).
Let’s suppose that you want to find all bold fragments of text in a document, and reformat them with the non-bold italic attribute.
Target Text:
string 1 normal string 1 string 2 normal string 2 string 3 normal string 3
Find What pattern:
[!^p]{1,}
+ Specific Font Format: bold
Replace With pattern:
+ Specific Font Format: non-bold + Italic
Result:
Note that similar operations can be done with the "Superscript", "Strikeout", "Underline", etc. font formats.
Also, please have a look at the attached document. It contains a number of examples of possible use of regular expressions in Atlantis.
Atlantis Regex Library.docx
(90.94 KiB) Downloaded 1953 times
Re: using wildcard search results as part of replace
DaleDe wrote:Is it possible to use the results of a wildcard search results in the replace portion? Is it collected in some fashion to be reused?
Please click the following link:
Parentheses () and group backreferences \n
DaleDe
Post by DaleDe »
Thanks I will look this over.
Dale
