I would like to be able to insert a horizontal line. (This is a supported ePub and html feature). I would like to be able to vary the length of the line. It could be placed on the insert menu.
Dale
horizontal line
Hi Dale,
I personally use the attached file which I have placed as an Atlantis Clip Library item.
I double-click on this "Horizontal Line" item in the Clip Library whenever I want to insert a horizontal line.
You’ll change the length of the line if you move the associated tab stop with the mouse along the horizontal ruler.
- Horizontal Line.rtf
- (1.44 KiB) Downloaded 1852 times
Here is another workaround.
The line in attached “horizontal_line.docx” was created by inserting the “Line 5” picture from the “Images” folder in the Atlantis Clip Library. I then resized the picture to make it shorter and thinner.
This kind of “line” is saved to ePub (see attached “horizontal_line.epub”).
- horizontal_line.epub
- (2.48 KiB) Downloaded 1914 times
- horizontal_line.docx
- (4.06 KiB) Downloaded 1870 times
Hi Robert,
In a discussion area, I would be looking for a solution to a problem and I would really appreciate the solutions you proposed. However, this is a wish list or feature request, not a solution to fix something in a current eBook. I really do appreciate your solutions (workarounds) and have learned from them but I am asking for, what I believe, is a feature in the product to avoid having to work around with images. Almost any feature you care to name could be accomplished in one way or another by substituting a picture.
Dale
Dale
Thanks I didn't realize that hr used a border property. Actually I would be happy with your first solution if implemented in a way that ePub would show it. I would think that it would be fairly easy to add a command that said it was drawing a horizontal line but implement it by using the tab leader code and then recognizing this as a special case to be translated to an <hr> in the ePub. I do really like the leader trick.
By the way, the HTML save does implement some sort of line out of the leader trick although I am not sure what it does.
Dale
Dale
Euan Mitchell
Inserting a line that is viewable in EPUBs
Hi Atlantis,
I would like to second Dale's request for a new feature that allows the insertion of a coloured line that will also appear when converted to an EPUB. It's something I use all the time in Word for adding a professional touch to my ebooks.
Euan
