Left Justified and Right Justified on same line?
Raymond
Post by Raymond »
Hello,
I know that tables are not supported (but I am hopeful that they may be later :) ) but what I often use tables for is to have a single line of text be both left justified and right justified.
Something like this:
(left justified) (right justified)
Dear Customer, 12/25/2013
Is there any other way to do this?
Many thanks, I am enjoying using Atlantis WP!!
-Raymond
Hi Raymond,
Note that paragraphs cannot be left or right “justified”. Paragraphs are either left, center, or right “aligned”. They can also be “justified”, which is a special kind of alignment. You’ll find details about paragraph alignment in the Atlantis help at Paragraph Format > Alignment
Now as such, paragraphs cannot be both left and right aligned. It is one or the other.
But there are at least two ways to place some text to the left of a line, and another text to the right of a line.
A. Using a right-aligned tab stop to place new text to the right of the line.
B. Using columns.
Please see the attached documents.
“(left aligned) (right aligned)_1.rtf” uses a right-aligned tab stop to place text to the right of the line.
“(left aligned) (right aligned)_2.rtf” uses 2 columns. The first column hosts a left-aligned paragraph. The second column hosts a right-aligned paragraph.
(1.59 KiB) Downloaded 553 times
(1.44 KiB) Downloaded 529 times
Raymond
Post by Raymond »
Robert,
Your columns example will work a treat for me!!
Thank you - that was exactly what I wanted!
I am enjoying using AWP... keep up the great work!
... and please keep an open mind re tables :)
Many thanks,
-Raymond
