Windows 7 no longer searches Atlantis files.
wood.22mark
Post by wood.22mark »
It appears that Microsoft is targeting Atlantis users. The search function on Windows 7 searched Atlantis files until my last update. Now it no longer does. I rebuilt my index. It still doesn't search Atlantis files. It does, however, search all .txt files in my recycle bin ... but not .rtf files. I have spent many days searching through the help files in Microsoft ... no help.
Yes, I verified that the indexing included rtf files. The icon even says Atlantis on the rtf option.
Any suggestions?
wood.22mark
DocFetcher worked well for me. I had to download it from CNET, though. I don't know why I couldn't download it from the parent site.
I do not think that Microsoft is targeting anyone. By the way, RTF is not a proprietary document format of Atlantis Word Processor. It is a proprietary format of Microsoft.
Please have a look at the following pages:
Windows 7 will not search my rtf files
Windows 7: Search does not find files that it should
wood.22mark
Thank you.
Billbo
Post by Billbo »
I have no problem with 64-bit Win 7 Home Premium on an HP laptop.
I know it not a solution, but it indicates that it does have the problem
on all machines.
Bill
P.S. This is the second time. Not taking my posts.
wood.22mark
Robert wrote:Please have a look at the following pages:
Thank you. I tried these things. They did not help. I am returning to DocFetcher. It not only works, it seems to work better than the original search program embedded into Windows.
This is under Windows 8 64-bit.
If I open Windows Explorer, navigate to “My Computer”, then search for “*.rtf” (without the quotes), all the RTF files present on my system get listed in the search results.
