Spellchecker does not install or I'm missing something.
Dr. Lowe
Post by Dr. Lowe »
After downloading form official page the Spanish spellchecker and installing (at least I think I have) my unregistered copy of Atlantis 1.6 does not show such installation has worked. Also in the Atlantis folder (program files...) only English files can be found. So I assume the installation didn't work. How I fix this?
After install of the Spanish spellchecker, you should have a file named “spanish.zlx” in your “My documents\Atlantis\Spellcheck” folder.
Is your copy of Atlantis up-to-date? Please choose the "Help | Check for Updates..." menu command of Atlantis. Does it say that a newer version of Atlantis is available?
Dr. Lowe
Post by Dr. Lowe »
Not to both. I don't have a file named 'spanish.zlx' nor I was up to date. Now I am and runned the 'atlantis_spellcheck_es' application (.exe) and still the same. It finishes oddly quick and indeed does nothing and I am still without the Spanish spellcheck.
Try downloading the Spanish spellchecker installer again.
Click on the following link:
http://www.atlantiswordprocessor.com/do ... eck_es.exe
Then close all running instances of Atlantis, and execute “atlantis_spellcheck_es.exe” on your system.
By the way, which Windows system are you running?
Dr. Lowe
Post by Dr. Lowe »
Fantastic, it works now so I can make the evaluation I need. I am using Seven but, by now, you dont need this info anymore.
Thank you.
