I have often used the Special Characters in Word but I can't find it in Atlantis. The help file starts with that dialog already up, but I can't find where to click to bring it up.
Thanks for the Help
Franklin
Where is the "Symbols & Characters" Dialog?
franklinreid
Hi Franklin,
You can use the main menu command "Insert | Symbol...", or the corresponding toolbar icon:
You might also want to take a look at the following pages:
http://www.atlantiswordprocessor.com/en ... symbol.htm
http://www.atlantiswordprocessor.com/en ... ps_012.htm
