Odd Computer Behaviour
peterjmerton
Post by peterjmerton »
Recently I had a disaster with my computer. I have had to re-install all software. Since this re-installation I have been having problems with Atlantis in that the Hot Keys are behaving abnormally. For example the Ctrl Alt Right Arrow hot key combination rotates the page through 90 degrees clockwise. Ctrl Alt Up arrow restores the layout.
The have been a couple of other funnies as well. Ctrl ] works, but Ctrl [ does not.
Is it possible that Excel 2010 could be the culprit? It is the only program installed which was not on my computer before the disaster, other than Windows 7.
Do you have any suggestions for me?
Regards, Peter.
Hi Peter,
It seems there is a conflict between some of the hot keys assigned in Atlantis and in your graphic card driver properties. Make sure that “Ctrl Alt Right Arrow” is not already assigned there.
Here is from http://answers.microsoft.com/en-us/wind ... 44e7127aeb:
“Some graphic devices do support a keyboard shortcut to rotate the screen, notably nVidia, enables the Ctrl+Alt+Arrow Keys.”
You might also want to have a look at this other thread:
http://forums.techguy.org/windows-xp/55 ... arrow.html
The problem with the other Atlantis hot keys is probably due to the same cause.
peterjmerton
Hot Key Problem Soved
Hi Robert,
Many thanks for your assistance with my Hot Key problem.
Problem solved.
Thanks again.
Regards, Peter
