Spellcheck underlining
Peter Sparrow
Every single word in my documents has suddenly been underlined in blue. EVERY word, even the numbers. Can anyone tell me what has happened and how to fix it please.
Two possible reasons:
1) Your document text is associated with a wrong language.
2) You do not have a spellchecker corresponding to your document's text language.
Please click here for details.
Peter Sparrow
Admin,
Thank you for your reply. It seems to be a problem with ver. 1.6.5.8 because I reloaded ver. 1.6.5.2 and the problem disappeared. The spellchecker now works normally.
I think ver. 1.6.5.8 is a beta version so maybe this is one of the problems which still needs to be sorted.
Thanks again.
Thanks again.
Hi Peter,
If spellchecking works normally with version 1.6.5.2, and not with version 1.6.5.8, the likely explanation is that for some reason your Atlantis spellchecker files have remained in their old location prior to version 1.6.5.8. For detailed explanations, please have a look at the release notes for version 1.6.5.8 (User-specific files).
Here is an excerpt:
Here is an excerpt:
So if you still have files within a “C:\Program Files\Atlantis\Spellcheck” folder, please move them manually to your "My Documents\Atlantis\Spellcheck" folder. And relaunch Atlantis.“All the spellcheck files of Atlantis are now supposed to be stored under the "My Documents\Atlantis\Spellcheck" folder. So if you have placed custom spellcheck dictionaries in a different location on your hard disk, you should move these dictionary files to the "My Documents\Atlantis\Spellcheck" folder manually yourself.”
