Home site of Atlantis Word Processor
Atlantis Word Processor Forum
 FAQFAQ   SearchSearch  RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Can't find tools for customizing
Post new topic   Reply to topic    Atlantis Word Processor Forum Index -> General
View previous topic :: View next topic
Author Message
oop
Posted: Tue Feb 21, 2012 1:27 pm    Post subject: Can't find tools for customizing Reply with quote
There are two tools on the Extended toolbar which I would like to have on the Formatting toolbar instead, but I can't find them in any of the lists of available commands on the left side of the "Toolbars" dialog. On the Extended toolbar they're called:
- Insert symbol
- Sort paragraphs in ascending order
Back to top
View user's profile Send private message
oop
Posted: Tue Feb 21, 2012 1:57 pm    Post subject: Reply with quote
Well, this is interesting. I looked again later and found both tools, in the All Commands category (the first place I looked), and I successfully copied them to the Formatting toolbar.
But then I looked again and they had reverted to not being in the All Commands category of Available Commands. And I've tried several more times, and they never re-appeared there. They've stayed on my customized Formatting toolbar though.
It seems like some sort of tiny bug. I'm using v1.6.1.9, on Vista Home Premium.
Back to top
Posted: Tue Feb 21, 2012 2:09 pm    Post subject: Reply with quote
There is no bug here.
Only the commands that are not already installed on the selected toolbar are displayed in the list of available commands.
You would find the "Insert symbol" and the "Sort paragraphs in ascending order" commands on the left if, on the right, you selected a toolbar where these commands are not already installed.
Back to top
Post new topic   Reply to topic    Atlantis Word Processor Forum Index -> General All times are GMT - 5 Hours
Page 1 of 1
  Did you know that ...
The contents of another document can be inserted in the active document. Choose Insert | File..., then select one or multiple documents to insert.
Powered by phpBB
