restore from system tray hotkey?
AEN007
Post by AEN007 »
How is the Restore from system tray hotkey supposed to work?
Atlantis hotkeys only work when Atlantis is active / in focus.
When Atlantis is minimized to the system tray, Atlantis can not be active / in focus ...
If you assign a hot key to the "Restore from system tray" command, it will work when the Atlantis window is not active.
Note that the system tray-related commands will be no longer available in newer versions of Atlantis Word Processor.
