I can't send a file from Atlantis, I am working on.
VJF
Post by VJF »
Since about a year I can not send (from Atlantis) the file I'm working on. (File - email - send by Email)
I can do so, using Jarte, using OO Writer, but not using Atlantis.
What do I do wrong? Or maybe Atlantis?
XP, SP3, Inspiron mini, 1Gb memory, Atlantis 1.6.5.7.
This is my start-up for Atlantis: D:\ATLANTIS\Atlantis.exe -lsi -ssi
Mozilla Thunderbird 6.0.2; standard mail program
Thanks in advance.
Vincent
Vincent van Gool, Amsterdam
Please see the Mapi Support article of the MozillaZine Knowledge Base. Was it of any help?
Please note that you can always manually attach any Atlantis document to a new message in your email client.
VJF
Post by VJF »
Thank you, Admin.
I think, I understand it. But it did not help.
I already did, what you advised in the second sentence.
I'll leave it as such.
Greetings,
Vincent
Hi Vincent,
You might want to try your luck running the following 3 Windows command-lines successively:
1. Click Start > Run, then type:
Code: Select all
regsvr32 mshtml.dll
Click OK.
2. Click Start > Run, then type:
Code: Select all
regsvr32 shdocvw.dll
Click OK.
3. Click Start > Run, then type:
Code: Select all
regsvr32 sendmail.dll
Click OK.
You might also try to launch Atlantis with its default command-line (“D:\ATLANTIS\Atlantis.exe” instead of “D:\ATLANTIS\Atlantis.exe -lsi -ssi”). See what happens.
VJF
Post by VJF »
Thanks Robert,
Helas; it does not help.
I'll walk the criple way.
Greetings,
Vincent
