Page break line has disappeared
Sentosa
Post by Sentosa »
Search didn't help
I used to have a nice black line indicating a page break.
Now I see nothing.
If I activate Special Symbols, I get
--Page Break--
and nothing else.
I'm guessing I inadvertently activated/deactivated some function but cannot identify which one.
Any ideas? Please? Help
Sentosa
Problem solved
Post by Sentosa »
Don't know what the problem was.
1. I uninstalled Atlantis.
2. I removed all Registry references to Atlantis.
3. I rebooted.
4. Re-installed Atlantis
Everything AOK.
Would have been interesting to have found the problem, but...
Please have a look at the “Special symbols” check box options on the “Tools | Options… > View tab”.
Most likely, you had unchecked all boxes.
Sentosa
Post by Sentosa »
Same issue has arisen. I use Atlantis for several hours each day. For example. I used it without any problems all weekend and for several hours this morning.
I have not changed any settings.
However, I after a break, I started Atlantis and opened the same document.
Page breaks are not showing. If I load a document containing many pages, but Atlantis goes not recognise pages. Bottom left of screen shows:
Sec 1/1; Line 1 Col 1
whereas this morning it was showing pages and total pages.
Not applicable to my first post, and not applicable now.
Any ideas?
Sentosa
Post by Sentosa »
Problem solved AGAIN BY UNINSTALLING and REINSTALLING. Seem to have lost my dictionary corrections unfortunately.
I'm starting to think I should give up on Atlantis (although I really like it) and perhaps return to current version of Word or Wordperfect. Certainly bears thinking about.
It is because you switched to the Draft View mode in Atlantis. There was no need to uninstall Atlantis. Just switch back to the Print Layout View.
