Wheel mouse won't work in Atlantis
Gayle
Post by Gayle »
I use a wheel mouse and it doesn't work in Atlantis.  Why not?
Re: Wheel mouse won't work in Atlantis
Regrettably the Wheel mouse will not work with Atlantis under Windows 95.
Van
Post by Van »
The wheel works fine in Win98 :)<br><br>Van
Out with it...
... also in Windows ME/NT/2000. &nbsp;8)
monitor
Post by monitor »
Just installed Atlantis Nova on WIN 98SE system and cordless wheelmouse doesn't work?
Does your mouse use additional software in order to work on your computer?
monitor
Post by monitor »
Yes,I installed Logitech Wheelmouse software/driver eons ago. Have used many, many different text and word processing programs and this is a first. <br><br>Also, since I first posted, I re-installed Atlantis Nova just in case, but still no mouse scrolling. &nbsp;
monitor
Post by monitor »
Hi,<br><br>Just returned from a trip over to Logitech where I downloaded some just released mouseware and, voila!, everything is A okay.<br><br>Am really looking forward to using Atlantis!
Most Wheel-mice (with a few exceptions) should work with Atlantis under Windows 98/NT/2000/ME. The mice that use additional software to emulate the Wheel, might not work with Atlantis.
polymath
Post by polymath »
Can this be fixed? I use Thinkpad Trackpoint with third mouse button, and the scrolling feature doesn't work. &nbsp;As far as I can tell, Atlantis is the only program (out of 100+) programs I have in my laptop that doesn't allow me to use the scrolling button in my Thinkpad.<br><br>Thanks.
Regrettably the wheel operations are not supported by Atlantis on Windows 95.<br><br>Also the Wheel mouse should work in "MS IntelliMouse" compatible mode (should support windows that do not contain standard scrollbars). Atlantis has a nonstandard window.
polymath
Post by polymath »
I don't use Windows 95. &nbsp;Running Windows 2000 SP2. &nbsp;As I said, this program is the only program that doesn't seem to work with my Thinkpad scroll button.
valin
Post by valin »
I run Win98SE and until recently could not get my mouse wheel to work with Atlantis. &nbsp;I was using Logitech's mouse drivers. &nbsp;They may work with others, but not with me. &nbsp;I downloaded and installed MS Intellimouse drivers and voila, the wheel now worked with Atlantis. &nbsp;Just a suggestion for those of you still stumped. ;D
