After a lots of testings exporting documents from Atlantis to ePub and checking under the famous Apple iPad, I have discover that Apple is not respecting the use of the font embedded, in the ePub file, perfectly generated by Atlantis !!
I have discover that a solution is to add in the font family feature of the css file regarding every style, after the family name, the generic family as serif, sans-serif, cursive or monospace, in accordance with CCS.
Dear O great Master of Creation of the fabulous application is Atlantis, could you be kind enough to add this feature in a quickest way ?
Here is an example for you (I know you know, but it's for readers...):
Before:
Code: Select all
.t0{
font-family:"Bell MT";
font-size:1em;
color:#ff6600
}Code: Select all
.t0{
font-family:"Bell MT", serif;
font-size:1em;
color:#ff6600
