'register' message
genxcapa
'register' message
Post by genxcapa »
I'm new to Atlantis. Started with the free trial version and then purchased. Now, every time I open a document, I get message that my trial is about to expire and I need to register or continue with trial. So, I have had to put in my code every time I open Atlantis. How can I make this stop? Thanks
As I understand, you are using a copy of Atlantis installed on the hard disk of your computer.
Please do the following:
1) Close all running instances of Atlantis in your Windows (if any). Make sure that there is no Atlantis button on the Windows Taskbar.
2) Launch a new instance of Atlantis by double-clicking the Atlantis icon on the Windows Desktop, or by clicking the "Atlantis" icon from the "Start > Programs > Atlantis" menu of the Windows Taskbar.
3) Choose the "Help | Enter Registration Code..." menu command of Atlantis, enter your registration details, and OK out of the dialog.
4) Close this instance of Atlantis (press Alt+F4, or choose the "File | Exit" menu command of Atlantis).
